Author Topic: 61/62 grilles  (Read 696 times)
123.caddy62
  • Guest
61/62 grilles
« on: November 05, 2008, 11:07:43 PM »
Are 1961,62,63 caddy grilles and fenderskirts interchangeable?        Paris
« Last Edit: November 06, 2008, 12:06:19 AM by 123.caddy62 »
Offline Dave Shepherd
Re: 61/62 grilles
« Reply #1 on: November 06, 2008, 07:09:01 AM »
61-62 skirts are the same, 63 is different. The 63 grille is also different, 61-62 may interchange, I am sure someone with more specific info will kick in here.
123.caddy62
  • Guest
Re: 61/62 grilles
« Reply #2 on: November 06, 2008, 10:17:32 AM »
Thank you for the info, much appreciated!!!!!!
Offline quadfins
  • Jim Eccleston CLC 16079
  • Administrator
Re: 61/62 grilles
« Reply #3 on: November 07, 2008, 01:45:00 PM »
61 and 62 grilles can interchange, but you have to swap out most of the sheet metal around the front inner fenders, as well as brackets, bars, and grille parts. Even the hood latch mounts are different. One might as well just get a correct replacement grille.
Jim Eccleston
1961 Coupe de Ville
BATILAC
