In answer to Chris's question , mine are 2.75''. I ordered 3.25'', same width as the new Coker bias ply tires I took off. They were only disappointing for a short while, because of the difference. If I had a show car, I would have kept the bias tires on an extra set of wheels for show. I like the looks of the 3.75'' whites, but that is getting close to the pavement on 225's. By the way, the D-Backs are still as white as the day I bought them. Mine is not a show car, but sometimes a show stopper.The main thing is make sure your wheels are in good condition, and sealing won't be a problem. One problem if you are searching junkyards and swapmeets for wheels, a car sitting for periods of years on flat tires will retain a large amount of water
and tend to deteriorate the metal around the valve stem hole ON THE INSIDE. So no matter how good it looks on the outside be sure to inspect the inside for severe pitting or rust in this area, it can get dangerously thin. You can weld a patch here and drill valve stem hole elsewhere if need be.
