Author Topic: 1959 Cadillac parts  (Read 5060 times)
1959 Cadillac parts
« on: April 15, 2009, 10:25:45 AM »
I have a ton of 1959 Cadillac parts. I have purchased several parts cars and parts lots to get parts for my 59 projects. If anyone is looking for any parts let me know what you need and I can check my inventory. Thanks, and good luck with your projects.  Brian 412 952 6027.
brian faull clc#25881
Offline hlouden
Re: 1959 Cadillac parts
« Reply #1 on: July 02, 2009, 05:03:34 AM »
Do you have A/C components for a 59 Cadillac? I have a Convertible. The pulleys and the brackets are on the car. I need dash vents, compressor, heater box and controls.
« Reply #2 on: July 03, 2009, 08:21:50 PM »
I have all those parts. I also have a set of re chromed dash vents and controls. Give me a call when you get a chance. Thanks, Brian. 412 952 6027.
Offline 59_limo
« Reply #3 on: July 07, 2009, 05:51:35 PM »
I'm looking for the 'FLEETWOOD' letter that go on the trunk bar.  Have any?
Chuck Stoops aka 59_limo
« Reply #4 on: July 07, 2009, 06:21:41 PM »
Do you need the whole fine line molding or just the letters? Thanks, Brian. 412 952 6027.
Offline Roger Zimmermann
  • CLC Number: 21015
  • Name: Roger Zimmermann
« Reply #5 on: July 08, 2009, 02:01:00 AM »
Do you have the rear grille for a Fleetwood, as well as the trunk rear molding AND the script Fleetwood? A light switch would also be welcome...
Roger
1956 Sedan de Ville
1957 Eldorado Brougham
« Reply #6 on: July 10, 2009, 10:43:09 PM »
I dont have any extra Fleetwood grilles. I do have a rear trunk bar, It is real bent but has the letters. I will check on the condition of the letters. Which switch do you need roger? Thanks, Brian. 412 952 6027.
  • CLC Number: 21015
« Reply #7 on: July 11, 2009, 01:48:09 AM »
Oups! I was meaning "Headlight" switch. Light switch could be something else. Please look at the condition of the letters; I was sure I could not find letters and molding in good condition at once.
1956 Sedan de Ville
Misfit
  • Guest
« Reply #8 on: July 11, 2009, 07:09:05 AM »
Roger. You might want to specify which headlight switch you need. The Fleetwood came with the fog light feature as standard equipment. There are two different switches used for the Fleetwood and other models.
MisFit
  • CLC Number: 21015
« Reply #9 on: July 12, 2009, 01:19:20 AM »
Usually it is the main switch which need replacement. The fog switch is an add-on; it can be transferred on the "new" switch.
Roger
1956 Sedan de Ville
« Reply #10 on: July 13, 2009, 06:32:38 PM »
Roger, I should have a few nice headlight switches. I just went out of town for about 2 weeks. When I get home I'll get you some pictures of the switch and the letters. Thanks, Brian. 412 952 6027.
Offline whitepink59
« Reply #11 on: July 25, 2009, 04:58:21 AM »
I need top control arm bushes and shafts for both sides of my front end.  Any in stock?
Cadrob
  • Guest
« Reply #12 on: July 25, 2009, 03:52:32 PM »
What city are you in? I'm going to be in Denver in August.
Rob
« Reply #13 on: July 25, 2009, 07:42:48 PM »
I live in Pittsburgh pa. I am just out in Colorado getting parts, I am leaving for Pittsburgh tomorrow. White pink, I am not sure what your looking for. I have several front ends if you need shafts or control arms.  You can buy control arm bushings new, if you just need bushings. You can call me if you want and we can figure it out. Thanks, Brian. 412 952 6027.
« Reply #14 on: August 07, 2009, 11:43:52 PM »
I just got back in town. Roger, the bent trunk bar is missing the t and the w. The remaining letters are pitted. If you are interested let me know and I'll send a picture. as for the headlight switch, do you just need the switch, or do you also need the chrome bezel and stem? I have a good used switch for $90 and a rebuilt switch for $115. I also have foglamp switches, knobs, and stems. The foglight equipped car has a longer headlight stem to account for the extra length of the foglamp switch. Let me know which one you need and I'll send a picture of it. Thanks, Brian. 412 952 6027.
Offline Antti
« Reply #15 on: August 12, 2009, 08:05:40 AM »
Hey, do you have a solid horn ring for -59 caddy? Other part I'm missing is a "FRONT SECTION"  of the Rear Quarter Panel Molding. I think it's same in both hand sides. The molding should be ONLY from: Serie 62 / De Ville and 2-door coupe models. Check the picture! If you have one please let me know, a.asunmaa@gmail.com.
http://img.photobucket.com/albums/v433/evoxgolf/Lhtkohta4-1-2.jpg
-Antti
« Last Edit: August 12, 2009, 08:07:43 AM by Antti »
Offline Antti
« Reply #16 on: August 14, 2009, 08:59:22 AM »
..Some more parts needed:
http://img.photobucket.com/albums/v433/evoxgolf/Cadi.jpg
It's the front wing's upper molding crest. If you have one, please let me know! (One piece is enough, but I can also buy a pair.)
-Antti
« Reply #17 on: August 16, 2009, 09:30:02 PM »
Antti, I do not have a horn ring or front quater moulding at this time. I have a few of the crests for the gunsights. I will take pictures this week and send them to you. Thanks, Brian. 412 952 6027.
Offline David Greenburg
  • CLC #3830
« Reply #18 on: August 16, 2009, 11:42:59 PM »
This is a bit obscure, but I'm looking for the following:
black kick panels for non-air conditioned car (the carpeted panel included the air vent assembly)
chrome fake "air intakes" that go on the rear doors of a 60S (no or very few pits)
the proper attaching hardware (cotter pin, washers etc.) used to connect the brake pedal to the master cylinder control rod
Good (no cracks) black and white steering wheel
The right or left hand end clips used to attach the trunk stainless trim (the end pieces are different than the inner pieces)
Will buy, or trade if you're interested.  I've got some foglight and autotronic eye parts among other things
David Greenburg
'59 Fleetwood 60S
Offline 5caddy9
« Reply #19 on: August 21, 2009, 05:05:49 PM »
Do you have the cadillac emblem for the centre of the steering wheel horn?
Chana
