Author Topic: 29 LaSalle: Distributor question  (Read 348 times)
Hank Vander Werp
  • Guest
« on: June 14, 2009, 09:33:46 AM »
The bakelite base of the distributor is froze in the potmetal base thus preventing the spark to be advanced or retarded.  We have tried freeing it with the usual, WD40 & PB Blaster, without any success.  Any suggestions on how to loosen up these two parts without breaking them?  Thanks
Hank
Offline 35-709
  • CLC Number: 4719
  • Name: G. Newcombe
Re: 29 LaSalle: Distributor question
« Reply #1 on: June 15, 2009, 04:58:39 PM »
Posted here not too long ago ------
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts.  Significant results!  They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
*Don't forget the April 2007 "Machinist's Workshop" magazine comparison
test.*
*They arranged a subjective test of all the popular penetrants with
the control being the torque required to remove the nut from a
"scientifically rusted" environment.*
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission
fluid and acetone.*
*Note the "home brew" was better than any commercial product in this one
particular test. Our local machinist group mixed up a batch and we all now
use it with equally good results. Note also that "Liquid Wrench" is about
as good as "Kroil" for about 20% of the price. *
1935 Cadillac Sedan
1973 Cadillac Caribou
When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that is the beginning of the end of any nation.
Offline Otto Skorzeny
« Reply #2 on: June 15, 2009, 05:12:26 PM »
What the hell is that?  Getting stuff to rust on a car ain't rocket science!
By the way, do you use Dexron, Type F or Honda-Matic in your "home brew"?
« Last Edit: June 15, 2009, 05:19:09 PM by ottoskorzeny »
fward
HUGE VENDOR LIST CLICK HERE
Offline 35-709
  • CLC Number: 4719
  • Name: G. Newcombe
« Reply #3 on: June 15, 2009, 05:30:36 PM »
 ;D  Haven't had occasion to try it yet, just thought it would be helpful.  If it is a GM car you are working on I would use Dexron of course!   ;D
1935 Cadillac Sedan
Offline Dan LeBlanc
  • Name: Dan LeBlanc
50/50 Acetone/ATF Mix
« Reply #4 on: March 13, 2010, 09:10:24 PM »
Ok, I hate dredging up old posts but I felt I had to on this one.  I tried the acetone/ATF mix as a penetrating oil tonight on the studs where the y pipe mounts on my 61 and on some muffler clamps.  I must say, it works abosolutely amazingly!  On the studs, I hardly had to torque on the nuts to break them free, and once they were, I could get them off with my fingers.
Just don't inhale the fumes - they're pretty strong.  It also starts to bubble when it hits the rust.
All in all, I'll never buy penetrating oil again!
Dan LeBlanc
1961 Fleetwood 60 Special - Work in Progress
« Reply #5 on: March 14, 2010, 08:35:48 AM »
I concur, Dan. I began using it after this thread and I won't be buying PB Blaster again. I wonder how hard it would be to package that brew in spray cans and sell it?
fward
