Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
IMPORTANT REMINDER:
All messages must be signed with a minimum of your first initial and last name.
Home
Help
Calendar
Login
Register
Cadillac & LaSalle Club Message Forum
Cadillac & LaSalle Club Forums
Technical / Authenticity
1976 Eldo, turn signal switch removal.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1976 Eldo, turn signal switch removal. (Read 396 times)
dave hanson
Guest
on:
August 14, 2009, 03:41:29 PM »
there is a rectanqular plate where the screw that holds the switch arm on would normaly be. appears to be no way to remove the arm
Logged
Ted in Olympia WA
25659
Re: 1976 Eldo, turn signal switch removal.
Reply #1 on:
August 14, 2009, 04:24:38 PM »
The arm unscrews. At the base you will see a flat spot for a wrench or pliers. What you have to watch out for is breaking your cruse control wire when you unwind it.
TED
Logged
Selling used Eldorado Parts from 1971-1978. Member Number 25659.
Administrator
CLC Number: 18992
Reply #2 on:
August 15, 2009, 04:35:53 AM »
The Workshop Manual is very specific in describing the removal and replacement of the arm.
It mentions that the arm takes 6 turns to remove, and when replacing, the wire has to be wound on 6 turns before attempting to re-install.
Bruce.
Logged
'72 Eldorado Convertible LHD
'70 Ranchero Squire RHD
'73 Chris Craft Gull Wing RHH
dave hanson
Guest
Reply #3 on:
August 15, 2009, 11:54:45 AM »
Thanks, Ted and Bruce , for the info
Logged
Print
Pages: [
1
Go Up
« previous
next »
