Author Topic: Body Colour Change  (Read 623 times)
Offline weephee
Body Colour Change
« on: January 14, 2010, 06:30:04 AM »
When a car is being restored and stripped down to the bare metal, does it matter if it is painted in a different colour than the original assuming the new colour is one that was offered by Cadillac at the time of production.   Does it affect value or desireability.   Thanks
Larry
Larry McPhee
Offline 76eldo
Re: Body Colour Change
« Reply #1 on: January 14, 2010, 08:05:54 AM »
If it is a car that has the trip tag on the cowl, which spells out the code for the original color(s) of the car, and you paint it a different color, it will have a negative impact on the future value of the car.  It's your car, so you can do what you want with it.  If you have to change the color, if you stick to a correct color that was available in that model year, you will lessen the negative impact.  In other words, painting a 50's or 60's car with modern pearl white would be totally incorrect, and although it might look great, it would not be period correct at all.
If you are planning to keep the car for a long time, make it the may you want it.
Brian Rachlin,
CLC # 22443
Current collection:
1960 62 Series Convertible
1976 Eldorado Convertible
1980 Hess & Eisenhardt Eldorado Convertible
1981 Hess & Eisenhardt Eldorado Convertible parts car
1985 Eldorado Convertible
1999 Eldorado Touring Coupe
Barry M. Wheeler #2189
  • Guest
« Reply #2 on: January 14, 2010, 09:35:12 AM »
As Brian said about using modern colors, there was a nice 1947 Cadillac convertible being painted in a fine shop some 20 miles from me a year or so ago. Turned out quite well, but since it was painted modern Cadillac Pearl white, the quality of the restoration did not show through, and it looked like a lead sled even though the car was done authentically. A total waste of money in my opinion. Try as you might, your eye simply expects the original type colors on a period car.
Offline The one that shall not be named
  • CLC 19XXX
  • Name: M. Stamps
« Reply #3 on: January 14, 2010, 10:36:10 AM »
I think the correct answer is it depends.  Say you have a 68 Convertible in Chestnut Brown.  It needs a repaint and isn't in good enough shape to keep it as an original paint.  If you paint it in San Mateo Red then if you want to sell later you will more likely have more lookers and therefore may be able to get a higher price.  So you use your proceeds and buy a 60 Convertible.  It too has worn factory paint but it's an original Ebony Black car.  Your new 20 year old girlfriend says that it would look great in aqua blue with red flames running down the sides.  You wanting to well lets just say make her happy decide to have it painted that way.  You just limited your market greatly and therefore the selling price if you want to get rid of it later.
Hope that helps,
Stampie
PS - In the end it's your car and do what you want.
If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law.  ~Henry David Thoreau, On the Duty of Civil Disobediance, 1849
If we desire respect for the law, we must first make the law respectable.  ~Louis D. Brandeis
Offline weephee
« Reply #4 on: January 14, 2010, 05:48:01 PM »
Thanks for the replies.   The car's original paint colour is a pale or light green which is not my taste.   I want to paint it black which should go with the black and white upholstery.   Now for a second question.   Is it OK or preferred to paint with whatever paint they use these days or do I need to paint it in the original type of paint.   As you can tell, I know nothing about types of paint.   Thanks
Larry McPhee
Offline 76eldo
« Reply #5 on: January 14, 2010, 05:57:17 PM »
Depending on the year, it was probably painted in acrylic lacquer, which is almost impossible to get a professional shop to use nowadays.
Base coat- clear coat is the industry standard, and that's how most cars are painted today.
i had to get some bumper fillers paint-matched for my black 76 Eldorado, and we had to select from a lot of different blacks.  They are NOT all the same.
Hope your body is very straight and ding and dent free if you want a nice job in black.
Brian Rachlin,
CLC # 22443
Current collection:
Offline kgray39011
  • CLC # 25781
« Reply #6 on: February 08, 2010, 06:07:04 PM »
I guess the two questions I have on this subject is:
1. If the car is all original (original engine) the impact of a different color seems much greater than if you had an incorrect car (non-matching engine).
2. But then if you have a less desirable color combination (either matter of opinion in this case or what is the perceived most popular), an off green versus say a red or black, it seems the impact would be much less.
I guess if I had an all original car I would want it the correct colors but if I had a non-original car I would want it my favorite color. Just my thought...
Ken
Kenneth P. Gray
Wife - 2010 Cadillac SRX Performance Package
Me - Looking for a 1941-1949 Coupe or Convertible Driver
Offline weephee
« Reply #7 on: February 08, 2010, 06:12:38 PM »
Thanks Ken.  The colour is an almost flourescent green.   In my opinion one of the most hideous colours I've seen.   It is original to the car and I can't live with it so a change will be in the works
Larry McPhee
Offline Brett Cottel
  • 1955 Cadillac Meteor Combination Hearse
« Reply #8 on: February 08, 2010, 10:45:00 PM »
There are some really stunning green colors out there......how about a sweet green color that isn't exact but still keep the flavor? I love green cars, especially if there is some gold in the color. There are even better green's than this car but I found this easily on the net.
Brett
« Last Edit: February 08, 2010, 10:50:55 PM by Brett Cottel »
1955 Cadillac Meteor Combination Coach
CLC #27535
Pic's at http://s981.photobucket.com/albums/ae293/brettcottel/
« Reply #9 on: February 09, 2010, 02:48:36 AM »
I agree with Brett!
Paul
53 Coupe
Twin Turbine
Offline weephee
« Reply #10 on: February 09, 2010, 06:16:10 AM »
I don't mind those greens but this one is more of a flourescent green.   You need sun glasses on when you look at it.   I think but I'm not sure that there was a dark green available in 68    If so, that is a colour I would consider for sure
Larry McPhee
Offline jagbuxx #12944
« Reply #11 on: February 09, 2010, 07:44:35 AM »
Look at code 36, Ivanhoe Green for 1968-it is a dark green. Or code 96, Monterey Green Firemist.
Frank Burns #12944
'76 Coupe deElegance EFI
'70 deVille Convertible
'61 Coupe Deville
'08 STS 3.6 1SC Package
'11 Camaro SS/RS
'03 Thunderbird
'07 Chevy Trailblazer LT 4x4
'06 National RV Dolphin 5320 V10
'01 Larson 190 LXI Bowrider
