Cadillac & LaSalle Club Message Forum
This Message Forum is to be used only to advance the purposes of the Cadillac & LaSalle Club, which are to develop, publish and exchange information pertaining to Cadillacs and LaSalles, to encourage the maintenance, preservation and restoration of Cadillacs and LaSalles, and to promote social fellowship among Club members.
Rules for posting messages in the Message Forum:
  • All messages must be signed with proper name (no "handles").
  • Non-commercial for sale or wanted ads are permitted, relating only to Cadillac or LaSalle cars, parts or literature (no commercial advertising of any kind is permitted; no ads for employment, trailers, or real properties are permitted).
  • It is highly recommended that all vehicle ads state an asking price and the location of the vehicle.
  • CLC members placing messages are asked to indicate name and CLC membership number, so other readers will know which writers are CLC members.
  • No disparaging remarks against other writers, Club members, vendors, or any other person are allowed.
  • No disparaging remarks about, or questioning of, judging results from Cadillac & LaSalle Club events are permitted.
  • If you find a message that does not appear to adhere to these rules, kindly bring it to the attention of the Webmaster.
The CLC reserves the right to delete or edit any message for any reason, and will delete all messages periodically based on length of time posted. Because of the public nature of internet access, the Cadillac & LaSalle Club cannot be responsible for the content of any message (whether or not from a CLC member), and the listing of any message in this Message Forum shall not be construed to indicate that the CLC endorses the content thereof.
Welcome, Guest. Please login or register.
Did you miss your activation email?     Registration is OPTIONAL and NOT REQUIRED to use this Forum!
March 12, 2010, 04:24:40 pm
The Missouri Valley Region has set up a Web site for all things relating to the 2010 Grand National.  Check it out at http://www.kcgn2010.com/.  You can read their blog and connect to their Facebook page from that link.
* CLC Home | Forum Home | Help | Search | Login | Register    Registration is OPTIONAL and NOT REQUIRED to use this Forum!
+  Cadillac & LaSalle Club Message Forum
|-+  Cadillac & LaSalle Club Forums
| |-+  General Discussion
| | |-+  Reason for Neg vs Pos ground?
« previous next »
Pages: [1] 2 | Go Down Reply | Print
Author Topic: Reason for Neg vs Pos ground?  (Read 940 times)
CLC #20664
Offline
Email
« on: February 04, 2010, 02:45:33 pm »
Was there a reason that for most of the early days of electrical systems Pos ground seemed to be the most common?
Any idea why the change?
Was the change usually at the same time as the change to 12v?
Was this all the same around the world?
Logged
StPaul/Mpls, MN USA
73 Eldo convert w/aftermarket EFI
75 Eldo rusty but trusty
Otto Skorzeny
Online
1956 Coupe de Ville aka Bismarck
Email
« Reply #1 on: February 04, 2010, 08:45:28 pm »
Great Britain retained "positive earth" as they say, at least into the 60s. I think everybody's negative ground today.
The switch to negative ground and 6v to 12v didn't always occur simultaneously with a particular make. Different makes switched at different times. Cadillac went + to - in 1946 but went to 12v in 1953.
Ford switched to 12v in 1956.
« Last Edit: February 04, 2010, 08:52:46 pm by Otto Skorzeny » Logged
Doug Houston #2257
Offline
Email
« Reply #2 on: February 06, 2010, 12:33:09 am »
I've covered this several times in the past, so I'll try to be a bit laconic here. The issue was distributor point erosion. It was thought that it was less with pos. ground, but it never seemed to make enough difference to sniff at.
Chrysler had a 12 Volt system in a couple of fifties era cars,and I think that they had positive ground. I'd need to check on it.
Chevrolet had a reversing switch on the distributor points, that reversed them each time the starter pedal was depressed. It was on my "41 Chevy as original equipment, but it was removed before I got the car. I have a new switch kit for it somewhere, but I doubt if I'llever install it. Everything's fine as is, so I'm going to let it be.
Logged
Otto Skorzeny
Online
Email
« Reply #3 on: February 06, 2010, 03:17:51 am »
So why the universal switch from positive to negative ground?
 As far as i know, it doesn't matter to electricity. As long as a circuit can be completed, everything works.
Why didn't everybody just stay with positive ground and use 12v?
Logged
MOTORNUT
Guest
Email
« Reply #4 on: February 06, 2010, 09:31:00 am »
Negative ground is universal now because modern electronics use negative ground.
Logged
Otto Skorzeny
Online
Email
« Reply #5 on: February 06, 2010, 01:43:31 pm »
Yes, we know that, but it still doesn't answer the question.
Modern electronics could easily be positive ground. Why, since positive ground was nearly universal for the first 50 years of automobile electrical systems, did the industry decide to convert to negative ground systems?
What is the reasoning behind the switch?
Logged
JKF
Guest
Email
« Reply #6 on: February 06, 2010, 03:48:14 pm »
Wouldn't surprise me if it has to do with patents. A handful of big manufacturers after WW1.
If I remember correctly from school the flow of current is from neg to pos. Lucas had something going once.
Bought an Austin Mini MkI 4spd Automatic 15 yrs ago that the seller never managed to fix the electrical system in. I Drove it all summer but had to recharge the battery several times. Finally I took the car to an older gentleman specialized in brittish cars. He looked under the hood, firmly shifted the battery cables to positive ground and told me to drive away. Far away.
Perhaps there are no fools anymore so "fool proof" positive ground isn't needed Grin
J Kjerrulf
Logged
Ted in Olympia WA
Online
25659
Email
« Reply #7 on: February 06, 2010, 04:18:10 pm »
I may be wrong but I bet it has to do with sourcing out the making of components like heater motors and starters.  To be more efficient it's better for everyone to be the same and cut costs.
I heard the main reason for going to 12 volts was to cut down on the amount of wire needed in the car.  I guess a 12 volt system needs a wire half the size to carry the same amps?  This saved on the copper needed and reduced cost.
TED
Logged
Selling used Eldorado Parts from 1971-1978.  Member Number 25659.  Olympia WA
Otto Skorzeny
Online
Email
« Reply #8 on: February 06, 2010, 05:22:45 pm »
Ted, your talking about 6v to 12v. The reason for that switch is obvious.
We want to know why negative ground is now universal whereas for the first half of the existence of the automobile, positive ground was universal (for all practical purposes).
The accessories can be and were built to whatever specs the car maker demands.  Makers of car heaters didn't produce a particular model a certain way then and tell GM to take it or leave it. It was and  is the other way around.
So the question still remains; Why did car makers decide to switch systems?
Logged
Bill Balkie 24172
Offline
1957 Cadillac Eldorado seville
wlb29
Email
« Reply #9 on: February 06, 2010, 07:22:20 pm »
Hello Otto, I think it all has to with corrosion of wires .The answer is simple enough..using negative battery reduces corrosion in the thousands of splice connections of the cables. The same technique is used in bridges and dams. A small negative (dc) current is passed through the steelwork and reduces electrolisys damage, or reverse electroplating the earth.  I am not an engineer but i found this out on the internet
Logged
Bill Balkie
warren rauch
Guest
Email
« Reply #10 on: February 07, 2010, 10:01:36 pm »
  In some of the earliest Service Man issues they sometimes answered questions like this.
  Date Jan1,1928 Q ; Why is the positive terminal of the battery grounded on Cadillac and LaSalle cars?
                         A: The positve terminal of the battery has always been grounded on Cadillac elcetricial systems. The advantage is that with this arrangement the positvie terminal of the battery is more easily replaced if it corrodes, and our expreience has shown that the positve terminal usually corrodes first.
    Believe it or not. Warren
Logged
The Tassie Devil(le) (Bruce Reynolds)
Administrator
Offline
Email
« Reply #11 on: February 07, 2010, 10:09:17 pm »
Oh, those were the days when things could be replaced, repaired, or just plain fixed without spending huge amounts of hard-earned cash.
Bruce. Evil
Logged
Bruce Reynolds,
# 18992
'72 Eldorado Convertible
Otto Skorzeny
Online
Email
« Reply #12 on: February 07, 2010, 10:39:49 pm »
Interersting Warren.
If that were really the case, though, why did Cadillac switch in '46? Certainly the laws of physics didn't change.
Probably just a BS answer because the guy was wondering the same thing we are today and no logical answer seems to be forthcoming. The mystery continues.
Logged
Whit Otis, 1188
CLC 1188
Offline
whitotis@msn.com
Email
« Reply #13 on: February 08, 2010, 04:22:51 am »
It seems that somewhere back in the dark ages, I read that positive ground was not universal back in the old days.... in fact that GM themselves did not universally use positive ground.... Cadillac was postive ground, but others such as Olds were not..... but, I don't remember the source on this.... also, the point that Doug Houston brought up was also reinforced as to why some makers used positive ground..... at this stage, I'm not willing to research it.... but it is an interesting topic nonetheless
Whit
Logged
Whit Otis - 1941 6219D Custom; 1940 7533F; 1948 6069X
Drawing of AP Sloan Custom by Terry Wenger
Glen
CLC #727 (life member)
Offline
Email
« Reply #14 on: February 08, 2010, 05:17:58 am »
I don’t think there was an overwhelming reason for the change to negative ground.  More than likely the need to standardize was the reason for some manufactures to change, but who would change was possibly determined by numbers.  There were more manufactures of negative ground cars than positive ground.  Or the manufactures of the negative ground cars were not willing to change so the rest had to make the change.
It’s also possible there were urban legends that influenced the change.  Such as “Lighting strikes more positive ground cars then negative ground cars”.
The change was probably not based on science but convenience and politics.
Glen
Logged
Bryan Thompson
Guest
Email
« Reply #15 on: February 08, 2010, 11:31:52 am »
Good Morning everyone,
After 14 posts I have been surprised no one has mentioned.......
Anyone ever work on the seat of their positive ground car (or other components) and see all the sparks when "grounding" the last connection? This would be very bad for electronic stuff. Not to mention scary.
Just my two cents.
Bryan
Logged
Otto Skorzeny
Online
Email
« Reply #16 on: February 08, 2010, 01:21:45 pm »
But the switch cam before the advent of electronics. Everything was still electro-mechanical in nature.
I imagine the choice probably was somewhat arbitrary but if it was the automakers that made the decision, I would imagine that GM, being the world's largest, carried the most weight.
Logged
Gergely Szentmartony 25603
Offline
1988 Cadillac Brougham d'Elegance
Email
« Reply #17 on: February 08, 2010, 04:54:49 pm »
It would also help to solve the enigma if we were sure whether Cadillac changed from + to - right after starting tank production (so tanks were all negative grounded) or tanks were all positive grounded and then somebody thought in 1945 that time had come to change to negative.
Unfortunately, I cannot find any information like that in the Service Manual: http://www.modifiedcadillac.org/documents/1940s/1944/1944%20Light%20Tanks%20Service/
I can imagine that military standards allowed only one kind of polarity (let's say the negative) because it reduced the number of further potential technical complications in the battlefields (Chrysler also produced tanks during the WWII). Then, after the WWII everything was ready to use as a negative ground system which did not make any sense to convert it (back) to positive ground.
So, maybe we just think that Cadillac changed to negative ground after the WWII. Maybe the military standards forced Cadillac to change it.
Of course, it is only my speculation which needs to be checked. However, I cannot find any other source than the above mentioned link to a Cadillac tank service manual.
Logged
"Brougham - For all the reasons you have ever wanted a Cadillac"
Otto Skorzeny
Online
Email
« Reply #18 on: February 08, 2010, 07:07:07 pm »
That's a good theory. Now we'll have to find out what the army did with everything.
My guess is that it wasn't standardized but who knows? The military bought all kinds of vehicles "off the shelf" including staff cars (some Cadillacs), trucks,  etc. and they were identical to the civilian versions. I'd suspect that there was a hodge podge of systems. Perhaps the"purpose-built" vehicles met some standard, however.
Logged
Doug Houston #2257
Offline
Email
« Reply #19 on: February 08, 2010, 07:10:59 pm »
Normally, after i answer something like this, I never open it up again. This one has gotten to be downright amusing. It will probably go on forever, with never a satisfying answer. There will probably be more theories offered, than cockroaches in Florida.
It rfeminds me of a guy, who once asked why a wheel is used to steer automobiles. Someone answered that the wheel was the most pracatical means of steering the vehicle, so it has been used since time immemorial. He than countered: But there MUST be a better way to do it. He had no ideas himself, but  while he never would admit it, he felt that, after all of those years, SOME improvement must be waiting in the wings. He was solidly convinced that, since time has passed with no chenges, then it was time for SOME change. Someone present suggested that he install a tiller bar on his car. That way, he'd have something different (though inferior), to possibly satisfy his desire for change. People are strange, and there are so many of them!
Logged
Pages: [1] 2 | Go Up Reply | Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.2 | SMF © 2006-2007, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
