I was referring to the valve on the LH exhaust manifold. If you live in a warm climate, then removing it and adding a spacer, or lengthening the take down pipe is an option.
When I was going through my car, I wanted to put it back correctly, so I put in a new one. My original was rusted up so badly that it never freed up after many soakings w/penetrating oil.
With that in the system, your freshly painted intake manifold will burn the paint off quickly on the crossover runners.
David
