Author Topic: Needed: Heat riser for '56  (Read 355 times)
Charlie Petty
  • Guest
« on: February 20, 2010, 10:47:08 PM »
Anyone have one?
Thanks much.
Offline Dan LeBlanc
  • Name: Dan LeBlanc
Re: Needed: Heat riser for '56
« Reply #1 on: February 21, 2010, 06:42:26 AM »
I believe these can be had new for around $120 from USA Parts Supply.
Dan LeBlanc
1961 Fleetwood 60 Special - Work in Progress
Offline David King (kz78hy)
  • Check out the new Eldorado Brougham Chapter
  • CLC Number: 22014
  • Name: David King
« Reply #2 on: February 21, 2010, 12:47:04 PM »
Cooper's has them as well.  That's were I bought mine.
David
David King
CLC 22014
1958 Eldorado Brougham's
1964 Studebaker Commander
1966 Pontiac GTO convertible
Director, Eldorado Brougham Chapter of the CLC
President, Motor City Region of the CLC
Charlie Petty
  • Guest
« Reply #3 on: February 21, 2010, 10:07:51 PM »
I see Cooper's is less expensive, but I was trying to avoid paying the price for a new one.  Guess the chances of finding a decent used one are slim.
Offline Otto Skorzeny
« Reply #4 on: February 21, 2010, 10:11:52 PM »
You can make your own pretty easily.
fward
HUGE VENDOR LIST CLICK HERE
Offline D.Yaros
  • '55 Coupe de Ville
  • Ed./Pub. Car Collector Chronicles
  • CLC Number: 25195
  • Name: Dave Yaros
« Reply #5 on: February 22, 2010, 04:15:47 PM »
tony@allcads.com has them, but they ain't cheap!
Otto - since this is a quite problem for all vintage car owners, would you care to expound a bit on the process of making a heat riser?  I for one would be interested; particularly since I have had to purchase this item for 2 different cars!
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
You will find me on the web @:
http://GDYNets.WebNG.com  -Dave's Den
http://GrayLady.WebNG.com -1955 Coupe Deville site
http://www.freewebs.com/jeandaveyaros  -Saved 62 (Oldsmobile) Web Site
The home of Car Collector Chronicles.  A  monthly GDYNets newsletter focusing on classic car collecting.
http://www.scribd.com/people/view/7936333
« Reply #6 on: February 22, 2010, 04:43:06 PM »
You're talking about the little tube that comes up from the passenger side manifold to the carb, right?
It's like making brake lines. Use the tubing benders to make all the bends. Use the old one for a pattern or use a piece of wire to get the shape and transfer it to the tubing.
I just searched my photos for pictures of mine during the rebuild but I couldn't find any. I wrapped it in that white braided cloth sleeve. I'll keep looking for a picture.
« Last Edit: February 22, 2010, 04:44:55 PM by Otto Skorzeny »
fward
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #7 on: February 22, 2010, 07:07:10 PM »
I think he's refering to the heat riser valve in the exhaust, not the choke heater tube.
Dan LeBlanc
« Reply #8 on: February 22, 2010, 07:34:32 PM »
Oh, that stupid thing.
Take it apart, remove the butterfly and put it back on. If you don't have one, leave it off and make your exhaust pipe an inch longer.
fward
  • CLC Number: 22014
  • Name: David King
« Reply #9 on: February 22, 2010, 08:07:46 PM »
I was referring to the valve on the LH exhaust manifold.  If you live in a warm climate, then removing it and adding a spacer, or lengthening the take down pipe is an option.
When I was going through my car, I wanted to put it back correctly, so I put in a new one.  My original was rusted up so badly that it never freed up after many soakings w/penetrating oil.
With that in the system, your freshly painted intake manifold will burn the paint off quickly on the crossover runners.
David
David King
CLC 22014
« Reply #10 on: February 22, 2010, 08:13:26 PM »
Right. They always rust up. Just put the housing in with the valve removed.
Even if you live in cold climes it will start and run just fine without it. Just let it warm up a little longer.
If there's snow on the ground you're not going to be driving the car anyway.
fward
« Reply #11 on: February 23, 2010, 09:16:36 AM »
Now this suggestion of eliminating the heat riser valve brings up the question of doing the same thing to a flathead.  In this case the action required would be to block the exhaust passage under the carb.  If the car is not driven in carb icing situations it seems like this would help in the summer by not having the intake manifold being heated continuously.  Has anyone tried this?
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 40-6267
Offline D.Yaros
  • CLC Number: 25195
  • Name: Dave Yaros
« Reply #12 on: February 23, 2010, 11:33:06 AM »
Well, that explains it.  No, that is not what I was thinking/talking about.  My reference is to the spring loaded flapper valve just below the exhaust manifold on the driver side.  With the passage of time they become frozen in either the open or closed position.
Easy to live with if frozen open, problematic if frozen closed.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #13 on: February 23, 2010, 05:50:50 PM »
I was able to get mine working again.  The car had sit in a field for 25 years and we use lots of salt here, so God knows how long before that it was rusted.  I took some stove oil (or furnace oil) and put it in a jar and soaked it for two weeks.  I then clamped it in a vice and was able to break it loose.  Worked it back and forth a few times and it was just as free as a new one and worked as such.  Didn't have to dismantle it or anything.  I've got another one for my 61 Fleetwood that I'm going to do also.
I'm also thinking of trying the 50/50 mix of acetone to transmission fluid as I read somewhere else on the site.  Apparently, it works better than penetrating oil, so I'm going to give it a shot.
Dan LeBlanc
