Author Topic: 1947 Steering Gear Lube  (Read 304 times)
Offline Frank Starr
« on: February 27, 2010, 09:45:03 PM »
What is the current product for steering gear lubricant?  The Shop Manual says GM 4673-M, but that deidn't make any friends at my local dealer.  They'd never had a request for manual steering gear lubricant.  Is there a NAPA substitute?
  • CLC #3877
Re: 1947 Steering Gear Lube
« Reply #1 on: February 27, 2010, 10:01:13 PM »
GM-4673M was used at least through 1955 or perhaps longer.  The generic equivalent is
90MP gear lube or more commonly known today it's 80W-90.  MP= Multi-Purpose
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
Offline Frank Starr
« Reply #2 on: February 28, 2010, 10:42:32 AM »
Thanks, Mike.
Would this be the same as 80 - 90 gearbox oil?
Frank
  • CLC #3877
« Reply #3 on: February 28, 2010, 04:28:58 PM »
Yes -- same thing.
2004 Escalade
Offline John Washburn CLC 1067
  • Call me on my shoe phone
« Reply #4 on: February 28, 2010, 08:17:43 PM »
Folks,
Not to make an easy answer complected, but today the rebuilders I know use a partial mixture of grease and 90 weight in the manual gear boxes. Using 90 weight alone generally results in leaks in these old boxes. I have used the following with 10% 80-90 weight oil in my 37 LaSalle and 49 Cadillac.
Gear Box Lube
Auto Restorer, April 2004, page 8
Gm Steering box lube (sold by Zip Products at 800+962-9632 under part number SC-601) with excellent results.
I have also used modern CV joint lube, which is available from any auto parts store. The GM Steering box lube and CV joint lube both have the consistency of light grease, making them less prone to leak past questionable seals.
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1953 Coupe DeVille
1956 Coupe DeVille
Offline Frank Starr
« Reply #5 on: March 01, 2010, 09:41:36 PM »
Thanks, John.  I wondered about that.  In fact, I recently rebuilt an early (1955) Saginaw power steering box for a 1955 Studebaker Coupe (yes, it was original equipment back then).  After considering all the factors, I used CV joint lube in the gear side of the unit.  I think I'll do the same again on the 47 Cad.
  • CLC #3877
« Reply #6 on: March 01, 2010, 10:26:55 PM »
Yes, I've heard about the leakage problem before.  The equivalent I gave you was from my old charts from Gulf Oil where I worked in the 60's.  That said, I'm sure that the CV joint grease
would work just fine in your steering gear box.
2004 Escalade
