Author Topic: 1957 fuel tank  (Read 268 times)
Offline Carl Schreiber
  • Name: C. Schreiber
1957 fuel tank
« on: March 01, 2010, 07:09:54 PM »
Hey all you 57 guys -
I just talked to Auto City Classic and they're re-popping the 1957 fuel tank!  No more $700 junk on fleaBay!!  Brand-new, dead-nuts PERFECT (like their 59-61 tanks).  From what I was told they're about 45 days out.  Man, this makes my day!
Carl Schreiber
Offline Bill Balkie 24172
  • 1957 Biarritz / 2009 CTS
Re: 1957 fuel tank
« Reply #1 on: March 02, 2010, 07:50:15 AM »
Hi Carl , That is good news ,  Will these tanks also fit the Eldorados with the side fill tubes ? Bill
eldorado with the fill tube on the side ?
Carl Schreiber
Bill Balkie
1957 Biarritz
2009 CTS
Offline Otto Skorzeny
Re: 1957 fuel tank
« Reply #2 on: March 02, 2010, 08:20:51 AM »
According to the MPB the same tank is used on all 1957 models including 1958 commercial chassis.
fward
HUGE VENDOR LIST CLICK HERE
Offline bcroe
Re: 1957 fuel tank
« Reply #3 on: March 02, 2010, 08:48:35 PM »
Does it fit the 57 Eldo with the rotary 3 wire sending unit?  David King is making a conversion module that allows a standard pickup to drive a rotary gauge.  Bruce Roe CLC #14630
Re: 1957 fuel tank
« Reply #4 on: March 02, 2010, 08:52:26 PM »
Put the what what in the what what?
All I know is that the MPB lists only one tank for 1957.
fward
Offline David King (kz78hy)
  • Check out the new Eldorado Brougham Chapter
  • CLC Number: 22014
  • Name: David King
Re: 1957 fuel tank
« Reply #5 on: March 02, 2010, 09:30:48 PM »
Thanks Bruce for the mention.
As all things Brougham, it is different than the standard fuel tank.  The standard 57 tank has the depressions on the top, but  the holes are not pierced for the Brougham low fuel tell tale sender, fuel gauge sender, or electric fuel pump.
The module Bruce speaks of is for the Brougham fuel sending unit as it has a different electrical circuit than the regular Cadillac.  This electronic module allows the use of standard Stewart Warner sending unit which will drive the Brougham fuel gage and light the low fuel lamp.
The Brougham had its own Master Parts List and none of Brougham parts show up in the regular Cadillac Master Parts List.
I am in the process of getting a box made to hold the circuit board to complete the module project.  A different version of this  module will replace the goofy oil sending unit that worked the same way.
David
David King
CLC 22014
1958 Eldorado Brougham's
1964 Studebaker Commander
1966 Pontiac GTO convertible
Director, Eldorado Brougham Chapter of the CLC
President, Motor City Region of the CLC
