Author Topic: 57 cad auto dimmer  (Read 261 times)
Dave R
  • Guest
57 cad auto dimmer
« on: March 07, 2010, 08:27:48 PM »
The auto dimmer on my 57 cad eldo doesn't work. I took the cover off and the tubes are not showing any filament glow. I can hear the vibrator humming and I measured 500vac but not sure if that is correct. Has anyone looked at their box and can you see the filaments on the tubes glowing when the head lights are on?
Offline Jose Gomez
Re: 57 cad auto dimmer
« Reply #1 on: March 08, 2010, 08:55:19 AM »
Dave,
There should only be one tube (the amplifier) that would have a glowing filament, this tube should the one at the opposite corner of the vibrator, and the taller tube should be the ballast.
The filament is power by the 12v source, and same source extends over to the ballast tube reducing the voltage at the vibrator. Since your vibrator is operational indicating a voltage from the 12v source, most likely the amplifier tube is bad. Just to validate you will need to test the tube, or you could test the filament pins 4 & 5 for continuity with an ohm meter.
Good luck..!
J. Gomez
« Reply #2 on: March 08, 2010, 11:42:33 AM »
As a related question, is there a switch built in to the circuit somewhere which will disable the Autronic Eye, giving one the option to use only "manual" dimming with the footswitch?  Dave, does your dimming function work okay with the footswitch?
Offline J. Wagnon
« Reply #3 on: March 08, 2010, 05:54:54 PM »
Dave,
John Oldenburg is THE autronic eye expert and is a super helpfull guy with great prices on all things autronic. You can reach him at 989-781-2946
« Reply #4 on: April 01, 2010, 09:51:12 AM »
I finally managed to track John Oldenburg down, but at the following 'phone number: (815)291-4384
