Author Topic: gas tanks  (Read 321 times)
Kerry Pilling
  • Guest
gas tanks
« on: March 10, 2010, 10:07:01 PM »
Does anyone out there no where I can get a gas tank for my 39 LaSalle Coupe. Any help would be appreciated! I tried all Cadillacs of the Forties, no help. My tank is toast. Thank You, Kerry
Offline Doug Houston #2257
Re: gas tanks
« Reply #1 on: March 10, 2010, 10:40:48 PM »
I think that your only hope wold be Detroit Radiator (if they're still in business). They were specialists is rebiuilding fuel tanks. Check the 248 area code listings.
« Last Edit: March 10, 2010, 10:42:23 PM by Doug Houston #2257 »
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
Offline Otto Skorzeny
Re: gas tanks
« Reply #2 on: March 11, 2010, 03:44:57 PM »
I recall a similar question in the past and the recommendation was another GM division which fit perfectly but wasn't 100% correct in terms of corrugations, etc. I'm sure someone will point out the whole deal. The search function above might help find the thread.
You might try looking at the new  tanks offered by Classic Car Auto Parts and see if any look close.
fward
HUGE VENDOR LIST CLICK HERE
Ross Dueringer
  • Guest
Re: gas tanks
« Reply #3 on: March 12, 2010, 04:58:13 PM »
Hello I put a 1950 Chevrolet tank in my 1939 LaSalle 50 series Coupe,  it does not hold as much gas but it has been in mine for 3 years no problems.    You have to change the straps and you have to tweek the fit but it works and I think I paid about $250.00 for it.
Offline Coupe
  • Paul Flykt CLC # 18899
Re: gas tanks
« Reply #4 on: March 12, 2010, 05:55:49 PM »
You may want to try Tanks, Inc. You may find one that will work. I've bought 2 tanks from them, 1 for my '38 Chev and 1 for my son's '46 pick-up. They were very helpful.
 Here's the link
http://www.tanksinc.com/index.cfm
1957 Coupe de Ville
