Author Topic: Mister Crane, my latest creation  (Read 1974 times)
densie 20352
  • Guest
« on: January 01, 2005, 07:20:41 PM »
   The story is, Im not supposed to lift anything over 20# or do anything strenuous, but I havent been able to give up playing around with cars, so I built Mister Crane to remove parts and carry them around.  The only problem now is that its kind of hard to push around in the soft sand, or over humps.   I have a small towbar that I may attach to it so that I can push it around with a garden tractor, or I may make it self-propelled.  Hmm...
http://www.americansoapbox.org/mrcrane/extension.jpg
-densie
Doug
  • Guest
Re: Mister Crane, my latest creation
« Reply #1 on: January 01, 2005, 07:56:20 PM »
Youd better watch out, it looks like hes trying to snatch your compressor!  Looks like hes already made away with your hood. . . Doug
Rhino 21150
  • Guest
« Reply #2 on: January 02, 2005, 07:24:03 PM »
Look in your phone book under "Material Handling". Somebody probably has "Beach" type wheels to fit your crane. I have a pair on my handtruck. They also make them to fit wheelchairs! I put a set on one. Also, have you Googled "surplus 12v motor"? Be amazed! I used to get catalogs in the mail (remember mail?) all the time for surplus industrial stuff. Then I got old.
BTW, Mr. Crane is way cool!
Rhino 21150
  • Guest
« Reply #3 on: January 02, 2005, 07:31:09 PM »
Go to this website. You wont learn much about twelve volt motors, although they are used heavily. You will laugh hard enough to be inspired once more! http://www.sashimitabernaclechoir.org/Construction-more.html
Dennis
  • Guest
« Reply #4 on: January 02, 2005, 09:02:10 PM »
I think youre playing with fire when using pneumatic wheels when dealing with lifting heavy and often unstable weights.  If the ground is so uneven that you have to resort to this type set up, how are you going to keep it from tipping over if a wheel goes into a depression or a signigicant rise in elevation? A 750 pound engine/tranny combo, raised high enough to clear the height of the radiator core support (which is already raised >12" higher for the pneumatic tires to clear the undercarriage is just asking for someone to get hurt and something to get broken.  A collective Oh S**T! will sond if the tip of the boom tilts too far left or right or the center of balance of the suspended weight or its momentum yanks the whole kit and kaboodle onto the ground.
Nice thought process, but Ill stay clear and come up with a better way to lift.  Thanks.
Dennis
  • Guest
« Reply #5 on: January 02, 2005, 09:07:42 PM »
....That is it you plan on lifting "heavy weights".  Using it for light duty shouldnt be a problem. (Suggest investing $600 and having a cement pad poured so you can easier get around, creepers, cranes and what not.
Dennis
densie
  • Guest
« Reply #6 on: January 03, 2005, 03:37:16 PM »
  I love the part about driving into the garage with the soloist up and decapitating him.  Ive already done that with Mister Crane...WHACK!
-densie
densie
  • Guest
« Reply #7 on: January 03, 2005, 03:43:45 PM »
  The last extension boom has a tested weight limit of 100#.  Thats where it begins to bow, but is still elastic to the bending load.  I wouldnt be crazy enough to lift an engine with that part of it!
  Heavy weights like engines have to be lifted on the center boom, then they can be lowered onto a little table that I attach to the front legs.  I lifted a big television this way...set the weight down on the legs so that it was nice and stable and then I could move it around with no problem.
-densie
