With #1 in TDC and the balancer on the timing mark, where should the rotor be pointing. In know it is "at #1". The question is, should the rotor be pointing directly to the back for #1 and directly to the front on #6. The shop manual refernces this a couple of times, but it is unclear. Currently, at #1 TDC, the rotor is pointing to the back and towards the drivers side at about the 2 oclock position. Im thinking that if the distributor is a tooth or two off, this may cause the problem as well.
