Author Topic: Brakes not right yet!! on 91 brougham  (Read 2299 times)
viator Trudeau
  • Guest
« on: February 18, 2005, 07:17:19 PM »
Spoke too soon, after the new booster the brakes still require way too much pedal pressure. All vac. lines to the booster are clear. In speaking W/ the Tech. at Cardone he said if the vac. supply was clear it cound be a bad booster.  Is there any thing could be amiss in the combination valve preventing fluid from going to the front or the rear brakes?  Any ideas?  I never had a problem like this before!!
David #19063
  • Guest
Re: Brakes not right yet!! on 91 brougham
« Reply #1 on: February 18, 2005, 11:33:19 PM »
Viator,
If it feels like you really need to use two feet on the brake pedal to stop, your booster has to be bad.  More than likely, the diaphram in it is torn or not attached on an edge.
Same symtoms as when the booster went bad on the 65 New Yorker I had, its 413-4 Wedge motor was a great engine.
David
