Author Topic: 1950 caddy fuses  (Read 1320 times)
Dave Grim
  • Guest
1950 caddy fuses
« on: February 20, 2005, 12:39:20 PM »
On my 1950 everthing works including the radio and ciggeret lighter and dome lights, but not my dash lights or heater blower.I cant find many fuses but the ones i find are ok, any ideas?...thanks
John Washburn CLC #1067
  • Guest
Re: 1950 caddy fuses
« Reply #1 on: February 20, 2005, 08:04:33 PM »
Dave,
Not many fuses on a 49/50 Cadillac. But the blower motors run through a 20 amp fuse that is also for the Flasher Unit. So you might want to check out the wires from the flasher to see if a fuse is in line with it.
John Washburn
CLC #1067
Dave Grim
  • Guest
« Reply #2 on: February 22, 2005, 09:36:42 AM »
Evry little bit of information helps,Thats something that i can check thank you.
