Author Topic: What size radial tires can I use on my 59?  (Read 1964 times)
R Jones
  • Guest
« on: February 20, 2005, 05:11:01 PM »
I have L7815 bias ply now.
Bruce Reynolds # 18992
  • Guest
225-75SR-15
« Reply #2 on: February 20, 2005, 08:54:44 PM »
Gday R again,
The tyres on my 60 CDV are Bridgestone 225 75SR 15 and although they seem to have a high profile, they really set the car off.   They can take any sort of bump in the road without causing damage, and handle the mass of the car with ease.
And, there is no problem with removing them from the rear axle if necessary.
Bruce,
The Tassie Devil(le),
60 CDV
David #19063
  • Guest
235 75R15s
« Reply #3 on: February 20, 2005, 09:49:00 PM »
I thought 235 75R15s were the replacement size for L78-15.
David
  • Guest
One would have to check for room at the rear
« Reply #4 on: February 20, 2005, 10:25:53 PM »
David,
They might be, but I have found that the 225s on my car perform really well, and I think at the time I purchased then, 14 years ago, I am not sure if 235s were even available.
And, I woulsnt be surprised if 235s will be difficult to remove through the space that is available in the 59/60 rear fender opening.
Bruce,
60 CDV
R Jones
  • Guest
THanks Ill look into Coker tires at 225 size
« Reply #5 on: February 21, 2005, 12:06:39 AM »
