Author Topic: 1969 vs. Drum Brake Master Cylinder Question  (Read 611 times)
alfredo barrenechea
  • Guest
« on: February 23, 2005, 11:44:17 AM »
Hi,
Is there a difference between the 69 (disc brake) master cyclinder and the 61-68 (drum brake) master cylinder?
I do know there is a bolt pattern difference, but what about reservior size?
I have heard that I can take a 69-76 metering block and use that.
Im converting my 64 to disc and Im trying to figure out the master cylinder side of things now.
thanks for any help.
-alfredo
Gene Roqueplot CLC #19950
  • Guest
Re: 1969 vs. Drum Brake Master Cylinder Question
« Reply #1 on: March 05, 2005, 08:43:26 AM »
Hello Al
I have not done this yet but have a 66 that i want to do! I remember reading that the rear wheel cylinders are different on a disc brake car. So i think that would be the reason the master cylinder is different. Go to the auto parts store and have them look up both master cylinders and see if the part # is different!
Take Care
Gene
Porter 21919
  • Guest
Part #s
« Reply #2 on: March 05, 2005, 09:04:00 AM »
I use the websites to look up part #s and cross reference part #s.
www.napaautoparts.com
www.rockauto.com
If you have a good parts counter guy you work with all the time or you can trust then ask him.
Porter, 66 & 67 CDV with most all parts interchangeable
Ed Mobley
  • Guest
« Reply #3 on: April 10, 2005, 10:50:04 PM »
The all wheel drum brake versions have a residual pressure valve (needed for drum brakes) on both parts of the master cylinder.  The disc bake version only has the valve on the rear section.
FWIW, I used an all wheel drum booster and m/c from a 68 Cadillac to convert my 60 to a dual reservoir setup (for safety).  If you search on my name, I posted the details of the conversion about a year ago to the general forum.
Ed
