Ifd its a 36-48 block, the engine number would be metal-stamped on the crankcase behind the LH cylinder bank, parallel to the edge of thew casting where the bell housing meets it. If its a 42 and later block, there is an extension of the RH cylinder deck just above the water pump where the engine number was metal stamped. The engine number was never cast in the block.
