Author Topic: 49-Type 48 plugs  (Read 819 times)
Art #22010
  • Guest
49-Type 48 plugs
« on: April 09, 2005, 06:31:34 PM »
   I have a set of type 48 plugs still in the box for my 49s62.
Would they still be good? Would you use them.
    Jeff, if your reading this I would like to see those picture again. I deleted them by mistake. Definately a sin.
                              Art #22010
JIM CLC # 15000
  • Guest
Re: 49-Type 48 plugs
« Reply #1 on: April 09, 2005, 11:22:17 PM »
04-09-05
Art, why not? plugs are not like a rad. hose would be. Nothing to deteriorate. But I would take very fine grit sand-paper and clean the contacts where the wires connect, and it will not hurt to clean and set the gap.
Good luck, Jim
Doug Houston
  • Guest
Re: 49-Type 48 plugs Hold on a minute!..
« Reply #2 on: April 10, 2005, 03:03:27 PM »
If you try to install spark plugs for a 48 Cadillac in a 49 head, youll play H--l getting them to stay in place. Cadillac had 10 MM threads on their spitzenpluggers from 1939-48, and changed to 14 MM plugs in 1949.
Jeff Maltby 4194
  • Guest
« Reply #3 on: April 11, 2005, 06:36:14 AM »
Art. Ill post the V16 pics tonite.
I have a 1949 vintage box of new AC48 spark plugs with coralox insulator that I plan on using-should work just fine.
Jay Friedman
  • Guest
« Reply #4 on: April 13, 2005, 04:10:13 PM »
I bought a set of NOS 48 plugs a couple of years ago and have driven my 49 5000+ miles since then.  The car performs perfectly with them and there have been no problems.  Jay
Art @22010
  • Guest
« Reply #5 on: April 13, 2005, 06:30:01 PM »
Thanks to all, I will use them. Art
