Author Topic: 1953 Fuel Pump  (Read 594 times)
Jim Govoni CLC 20546
  • Guest
1953 Fuel Pump
« on: April 12, 2005, 10:54:32 AM »
Hello: My 53 series 62 has a small fuel leak. I looks as if it is right under the filter bowl. When run for a while and then shut off, the bowl has little tiny bubbles in it. It seems to leak a couple of teaspoons each use. Need a replacement or something else? Many thanks, Jim
daniel
  • Guest
Re: 1953 Fuel Pump
« Reply #1 on: April 13, 2005, 06:05:07 AM »
Jim,
Whats the part number? I might have one for you that is already rebuilt.  My 49 came with a 53 engine and a rebuilt, unused fuel pump.  You can have it for cheap.
Dan
e-mail me direct.
John Washburn CLC #1067
  • Guest
Re: 1953 Fuel Pump
« Reply #2 on: April 14, 2005, 05:22:41 PM »
Folks,
Remember that the new oxygenated gas fuels eat the old rubber, so an old rebuilt fuel pump is prone to failure using the new gas.
See the recent edition of the Self Starter for more info.
John Washburn
CLC #1067
Jim Govoni
  • Guest
Re: 1953 Fuel Pump
« Reply #3 on: April 15, 2005, 07:30:31 AM »
Thanks! I found one on EBay. Hopefully itll work out. Jim
