Author Topic: 1978 Cadillic Seville  (Read 720 times)
Herbert Carlson
  • Guest
« on: April 13, 2005, 09:53:59 AM »
I would like to have the location of each of the lubrication fittings of the 1978 Seville!  Thank you
Mike #19861
  • Guest
Re: 1978 Cadillic Seville
« Reply #1 on: April 13, 2005, 02:17:22 PM »
 1 each - 2 upper ball joints
 1 each - 2 lower bal joints
 1 each - 2 outer tie rod ends
 1 each - 2 inner tie rod ends
 One on each enf of the idlwer arm
 One on the pitman arm at the centre link
 Some have fittings on the driveshaft double cardin joints. A special grease adaptor is required.
